VOSS v9.1 User Guide Version 9.1
> Inter-VSN routing configuration using the CLI
Published October 22, 2024
Abstract
Preface
Document Revision Changes
Port Down State
Wait States
UNI State
NNI States
Fabric Attach (FA) States
Fabric Extend (FE) States
Voice State
Auto-sense Fabric NNI
Auto-sense Voice without NAC
Auto-sense Voice with NAC
Auto-sense FA Proxy Switch
Configure ZTP+ Using the CLI
Managing the Switch
System Logon
Password Encryption
TLS Server for Secure HTTPS
Enhanced Secure Mode
Password Requirements
Sensitive File Protection
System Flags
Basic Configuration Using CLI
Enable CLI Access Levels
Configure the CLI Banner
Configure an Access Policy
Create Multiple CLI Users
Delete a CLI User Name
Enable a CLI User
Disable a CLI User
Back Up Configuration Files
Enable Access Levels
Configure the Logon Banner
Create an Access Policy
Enable an Access Policy
Modify CLI User Passwords
Disable a CLI User Account
Delete a CLI User Account
Display Local Alarms
Display Log Files
Enable Enhanced Secure Mode
Configure the Reuse Rule
Restart the Platform
Shut Down the System
Calculate the File Checksum
Reset System Functions
Source a Configuration
Enable Debug Mode
Enable Flow Control
Enable System Logging
Enable Automatic Reboot
Enable Trace Logs
Configure the Time Zone
Configure CLI Logging
Extend System Message Control
Hardware Status Using EDM
Command Completion
Log on to the Software
Use the chassis shortcut menu
Use the port shortcut menu
Use a table-based tab
Undock and dock tabs
Install EDM Help Files
Verify the Upgrade
Commit an Upgrade
Enable ARP Proxy
Clear ARP Entries
Show ARP Table Information
Configure Gratuitous ARP
View ARP Entries
Create Static ARP Entries
Configure ARP Proxy
Anycast IP Gateway
Anycast IP Gateway Operations
I-SID Attributes TLV 187
Anycast IP Gateway Benefits
Operational Considerations
BGP and Dampened Routes
MD5 Message Authentication
BGP and Route Redistribution
View CIDR Routes
View BGP Confederation
View Flap-Dampened Routes
View Imported Routes
View BGPv6 Imported Routes
View BGP Redistributed Routes
View BGP Routes
View BGPv6 Routes
View BGP Global Stats
View BGP Route Summary
Node Alias
Configure Port Lock
Configure SONMP
Display Power Status
View Entity Child Indexes
Configure Node Alias Globally
Graph Chassis Statistics
Graph Port Statistics
View Chassis SNMP Statistics
View Chassis IP Statistics
View Chassis TCP Statistics
View Chassis UDP Statistics
DHCP and UDP Configuration
DHCP Fundamentals
DHCP Server
DHCP Custom Options
DHCP Vendor Options
High Availability
DHCP Server Deployment Types
DHCP Relay
DHCP Option 82
UDP Broadcast Forwarding
Configure DHCP Custom Options
Configure DHCP Subnet
Enable DHCP Server
Clear DHCP Server Leases
Clear DHCP Server Logs
Configure a Vendor Class
DHCP Relay Configuration
Configure DHCP option 82
Show DHCP Relay Information
Configure UDP protocols
Create a DHCP Server Subnet
Enable DHCP Server
Create the Forwarding Profile
View UDP Endpoint Information
Modify DHCP Relay for a VLAN
Modify DHCP Relay for a Port
DvR Isolated Domains
DvR-VRRP Coexistence
Configure a DvR Controller
Configure a DvR Leaf
View DvR Summary
View DvR Database Information
View DvR Backbone Entries
Configure Fail Open VLAN
Display Port VLAN Information
Configure the Guest VLAN ID
Clear an EAP Client Session
Clear the NEAP Session
ExtremeCloud IQ Support
Configure IPsec Compression
MAC-in-MAC Encapsulation
Basic SPBM Network Topology
IS-IS Hierarchies
IS-IS Route Tagging
Auto-nickname for SPBM
Run the SPBM Script
Display IS-IS Areas
Configure SPBM parameters
SPBM Configuration Examples
Logical IS-IS Interface
FA Data Processing
View Fabric Attach Statistics
View FA statistics
Insert a Zero Touch Client
Layer 2 VSN Configuration
View the I-SID interface
Verify Layer 2 VSN operation
ECMP Within IS-IS routes
Configure SPBM IPv4 Shortcuts
IKE Limitations
Rendezvous Point Router
Configure PIM on a Port
Configure SSM Globally
Configure IPv6 SSM Globally
Configure IGMP on a VLAN
Configure IGMP Ports
Configure IGMP on a VRF
Enable PIM on a Port
Enable IPv6 PIM on a Port
Enable IPv6 SSM Globally
Enable MLD Trap Generation
Enable MLD Log Status
Configure MLD Version
Configure the MLD Robustness
Enable MLD Snooping on a VLAN
Display MLD System Parameters
Configure MLD Globally
MLD Interface Configuration
Configure an MLD Interface
Configure MLD on a Port
Configure MLD on a VLAN
Enable MLD Snooping
View MLD Cache Information
View MLD V2 Cache Information
View MLD Source Information
View MLD Sender Information
View MLD Group Information
Configure Static RP
Configure IPv6 PIM Static RP
Enable Square-SMLT Globally
Enable Static RP
Enable IPv6 Static RP
Configure a Static RP
View the Active RP
View the IPv6 Active RP
View Current BSR Information
Edit PIM Interface Parameters
Viewing RP Set Parameters
Configure a Candidate RP
View IPv6 RP Set Parameters
Configure IGMP Static Members
Change the SSM Range Group
Configure the SSM Map Table
Configure Fast Leave Mode
Enable IGMP snoop on a VLAN
Configure the IGMP Interface
Configure IGMP Sender Entries
View IGMP Cache Information
View IGMPv3 Cache
View IGMP Snoop Information
Configure Prefix Lists
Add New Static Source Groups
Edit Static Source Groups
Configure Mroute Stream Limit
TLVs
View the IGMP Interface Table
Static Data I-SID
Enable IPFIX Globally
Display IPFIX Global Status
IPsec Modes
Configure an IPsec Policy
IPv4 Interface State
Flush Routing Tables by Port
View all IP Addresses
Delete a Static Route
View IP Routes
View TCP Global Information
View IPv6 Connections
Create an IPv6 CLIP Interface
Enable IPv6 ECMP
Disable IPv6 ICMP Multicast
View IPv6 Default Routers
Configure an IPv6 Prefix List
View ICMP Statistics
Configure a IPv6 Prefix List
Configure Route Advertisement
Configure a Tunnel
Modify Tunnel Hop Limits
Configure a Tunnel
Clear KHI Statistics
Display KHI Port Information
DHCPv6 Security Concerns
FHS Restrictions
FHS Configuration Guidelines
Enable ND Inspection Globally
Clear a Dynamic SBT Entry
Create an IPv6 Access List
License File Requirements
Feature Licensing
Configure LACP Parameters
View LACP Port Statistics
View Global LLDP Statistics
Control Link State Changes
Display Link State Changes
LST Configuration Using CLI
Configure LST
LST Configuration Using EDM
Configure LST
Configure Secure Forwarding
Configure Logging
View Logs
Configure an SNMP Host
Enable SNMP Trap Logging
MACsec Components
View MACsec Statistics
SMLT Traffic Flow Examples
Display MLT Names
View MLT Statistics
View MLT Port Members
Add Ports to an MLT LAG
Remove Ports from an MLT LAG
Create a Virtual IST
View vIST Statistics
Edit a vIST
Configure SLPP Guard
View SLPP Guard Status
Add a Multilink or LACP Trunk
Add Ports to an MLT
View SMLT Statistics
View MLT Interface Statistics
View Trunks
Edit a Virtual IST
SLPP Guard Configuration
NTP Authentication
NTP Configuration Using CLI
Configure NTP Master Mode
Create NTP Restrict Entries
NTP Configuration Using EDM
Create NTPv4 Restrict Entries
Autonomous System and Areas
OSPF and Route Redistribution
Configure OSPF Globally
View OSPF Errors on a Port
Configure an OSPF Host Route
Configure OSPF NBMA Neighbors
Clear IP OSPF Statistics
View the VRF Configurations
View the VRFIDS
Create an OSPF Area
Create OSPF Area Ranges
Create an OSPF Virtual Link
Configure OSPF on a Tunnel
Add an NBMA Neighbor
Enable OSPF Globally
Configure an OSPF interface
View Port OSPF Statistics
Configure OSPF on a VLAN
View Virtual Neighbors
Configure Host Routes
Enable ASBR Status
Manage OSPF Neighbors
Configure OSPFv3 Globally
Create an OSPFv3 Area
Create an OSPFv3 Virtual Link
View the Area-Scope LSDB
View the Link-Scope LSDB
View OSPFv3 Neighbors
Disable PoE on a Port
Configure Port Power Priority
Display PoE Port Status
Service Classes
QoS Ingress Port-Rate Limiter
QoS and Channelization
Enable DiffServ for a Port
Configure the Port QoS Level
Configure Port-Based Shaping
Configure Port Rate Limits
Configure RADIUS Profile
Enable RADIUS-SNMP Accounting
View RADIUS Server Statistics
Enable OCSP Checking
Show RADIUS Server Statistics
Display RADIUS CoA Statistics
Configure the RESTCONF Server
Configure RIP Globally
Configure RIP on an Interface
Configure RIPng Globally
Configure RIPng Custom Values
View RIP status
Configure RIP on a Port
Configure RIP on a VLAN
Graph IPv6 RIPng Statistics
Configure RMON
Display RMON Address Maps
Display RMON Status
Enable RMON Globally
Enable RMON on a Port or VLAN
Enable RMON1 History
Disable RMON1 History
View RMON1 History Statistics
Create an RMON1 Alarm
View RMON1 Alarms
Delete an RMON1 Alarm
Create an RMON1 Event
View RMON1 Events
Delete an Event
View the RMON Log
Enable RMON Statistics
View Address Mappings
View Network Host Statistics
Configure a Prefix List
Enable RSMLT Edge support
SD-WAN
SD-WAN Local Breakout
SSH Rekeying
Clear SSH Sessions
Enable SSH Rekey
Configure Directed Broadcast
Configure Port Lock
Configure an sFlow Collector
View sFlow Statistics
Clear sFlow Statistics
Display sFlow Statistics
SNMP Configuration Using CLI
Create a New User Group
Block SNMP Access
SNMP Configuration Using EDM
Show SNMP Statistics
Display RSTP statistics
Display the RSTP Status
Display the RSTP Role
Configure MSTP MSTI Options
Configure Ethernet MSTP
Configure Ethernet MSTP MSTI
Display MSTP Configurations
Display MSTP Status
Display MSTP Port Information
Display MSTP MSTI Information
Display MSTP Statistics
Configure RSTP Ports
View RSTP Port Status
View RSTP Status Statistics
Configure CIST Ports for MSTP
Configure MSTI Ports for MSTP
SPB-PIM GW Components
Configure MSDP on a VRF
Enable MSDP Globally
Create an MSDP peer
Configure a Peer Description
Secure Control Messages
Clear the Peer Connection
Delete an MSDP Peer
Filter PIM Routes
Filter SA Messages
Configure MSDP Mesh Groups
Clear the MSDP SA Cache
Display the Peer Information
Display the SA Cache
Display the MSDP Count
Display the MSDP Summary
Display All MSDP Information
Clear IPv4 MSDP Statistics
Enable MSDP
Create an MSDP Peer
Change the MSDP Peer Status
Delete an MSDP Peer
Filter PIM Routes
Filter SA Messages
View Peer Information
View the Local SA Cache
View the Foreign SA Cache
View the Mesh Group
Controller configuration
Display Foreign Sources
Enable the Gateway
Enable the Gateway Globally
Display the IP mroute Routes
Source Specific Multicast
Peer Mesh Group
Multi domain
SPB domain interconnect
TACACS+ Fundamentals
TACACS+ Operation
TACACS+ Architecture
TACACS+ Authentication
TACACS+ authorization
TACACS+ Accounting
TACACS+ Feature Limitations
Enable TACACS+
Add a TACACS+ Server
Configure TACACS+ Accounting
Configure TACACS+ Globally
TACACS+ Configuration Example
Traffic Filtering
Overview of Traffic Filtering
QoS and Filters
Access Control Lists
Access Control Entries
Operators
Attributes
Conflict and Precedence
Switched UNI ACL Filters
Traffic filter configuration
Create an IPv4 ACL
Create an IPv6 ACL
Associate VLANs with an ACL
Associate ports with an ACL
Rename an ACL
Disable an ACL
Delete an ACL
Clear ACL Statistics
Enable IPv6 Egress Filters
View ACL Statistics
Configure ACEs
Configure ACE actions
Configure ARP ACEs
Configure an Ethernet ACE
Configure an IP ACE
Configure an IPv6 ACE
Configure a protocol ACE
View ACE Statistics
Configure an ACE
Configure ACE Actions
Configure ACE ARP entries
Configure an ACE IP DSCP
Configure an ACE IP protocol
Configure ACE IP options
Configure an ACE Source Port
Configure an ACE TCP Flag
View ACE Port Statistics
Data Collection for an Outage
Troubleshooting Fundamentals
Connectivity Problems
Routing Table Problems
Cable Connection Problems
Alarm Database
LED Indications of Problems
Connectivity Fault Management
CFM Fundamentals
Maintenance Domain (MD)
Maintenance Association (MA)
Fault Verification
LBM Message
L2 Ping
Fault Isolation
Link Trace Message
L2 Traceroute
L2 Tracetree
L2 Tracetree-fan
Layer 2 Tracemroute
Nodal MPs
Nodal B-VLAN MIPs with SMLT
CFM Configuration Using CLI
Autogenerated CFM
Trigger a Loopback Test (LBM)
Trigger Linktrace (LTM)
Trigger a Layer 2 Ping
Trigger a Layer 2 Traceroute
Trigger a Layer 2 Tracetree
Trigger a Layer 2 Tracemroute
CFM Configuration Using EDM
Autogenerated CFM
Configure Explicit CFM
Configure CFM MD
Configure CFM MA
Configure CFM MEP
Configure CFM Nodal MEP
Configure Layer 2 Ping
Initiate a Layer 2 Traceroute
Configure Layer 2 IP Ping
View Layer 2 IP Ping Results
Trigger Linktrace
View Linktrace Results
Configure a Layer 2 Tracetree
CFM Configuration Example
CFM Sample Output
Troubleshooting Overview
Debug Files
Flight Recorder
Port Mirroring
General Diagnostic Tools
Use CLI for Troubleshooting
Use Software Record Dumps
View and Delete Debug Files
Configure Port Mirroring
Display Mirror Resource Usage
Ping an IP Device
Run a Traceroute Test
Show SNMP Logs
Configure I-SID Monitoring
Configure ACLs for Mirroring
Configure ACEs for Mirroring
Run a Ping Test
View Ping Results
View Ping Probe History
View Traceroute Results
View the Traceroute History
General Troubleshooting
Hardware Troubleshooting
Layer 1 Troubleshooting
Layer 2 and 3 Troubleshooting
Troubleshooting BPDU Guard
Troubleshooting IPv6 VRRP
VRRP Transitions
Troubleshooting RSMLT
RSMLT Peers Not Up
Troubleshoot vIST Failure
Multicast Troubleshooting
Use PIM Debugging Commands
Troubleshooting Fabric Attach
Troubleshooting FAN Transit
Upper Layer Troubleshooting
Troubleshooting SNMP
SNMP Trap not Received
Troubleshooting DHCP
Troubleshooting DHCP Relay
Troubleshooting TACACS+
Unable to Log On Using Telnet
Unable to Log On Using SSH
Unable to Log On by any Means
Troubleshoot TACACS+ Problems
Use BGP Debugging Commands
Traps Reference
Proprietary Traps
Standard Traps
VLACP Flap Detect and Damping
VLACP Configuration using CLI
Configure VLACP on a port
Configure VLACP Globally
VLACP Configuration using EDM
Enable VLACP Globally
Configure VLACP on a Port
VLAN Configuration
VLAN Fundamentals
Port-Based VLANs
Policy-Based VLANs
VLAN Tagging and Port Types
VLAN Router Interfaces
IP routing and VLANs
VLAN Implementation
VLAN Configuration Rules
VLAN Feature Support
Supported NLB Topologies
VLAN loop prevention
Switched UNI Layer 3
VLAN Configuration Using CLI
Create a VLAN
Create a Private VLAN
Perform a General VLAN Action
Limit MAC Address Learning
Add or Remove Ports in a VLAN
Configure NLB support
Configuring SLPP
View SLPP Information
Configure Spoof Detection
View VLAN Information
View Private VLAN Information
View Brouter Port Information
View VLAN Port Member Status
View Port-Level MAC Security
View NLB-Mode Information
VLAN Configuration using EDM
Configure a VLAN on a Port
View existing VLANs
Create a Port-Based VLAN
Change VLAN Port Membership
Create a Protocol-Based VLAN
Create a SPBM B-VLAN
Configure NLB Support
Configure SLPP Globally
Configure the SLPP by VLAN
Configure the SLPP by Port
Configure Static Forwarding
Configure Limit Learning
VRF Lite
VRF Lite Fundamentals
VRF Lite Configuration Rules
Create a VRF Instance
Create an IPv6 VPN Instance
Configure a VRF Instance
View Statistics for a VRF
VRRP Fundamentals
Critical IP Address
VRRP Backup Master
VRRP Fast Hello Timers
VRRP Holddown Timer
VRRP and SMLT
VRRP and Spanning Tree
VRRP for IPv6
VRRPv3 guidelines
Configure VRRP Using CLI
Display Extended VLAN VRRP
View IP VRRPv3 Statistics
Enable IPv4 VRRP Preempt Mode
Configure the VRRP Interface
View VRRP Information
View IPv6 VRRP Statistics
Enable IPv6 VRRP Preempt Mode
Configure VRRP using EDM
Enable VRRP Global Variables
Configure VRRPv3 Checksum
View VRRP Statistics
Graph IP VRRPv3 Statistics
Graph IPv6 VRRP Statistics
VXLAN Gateway
VXLAN Gateway Fundamentals
VXLAN Modes
Configure VXLAN Gateway
VXLAN Gateway show commands
Display VNID Information
Configure OVSDB Replication
Configure a Remote VTEP
Configure a VNID
Configure VNID Endpoints
Configure ELAN Endpoints
Display the VTEP Next Hop
Configure OVSDB Globally
Configure an OVSDB Controller
VSP 4900 Series
VSP 7400 Series
Interface Indexes
Port Interface Index
VLAN interface index
MLT interface index
Supported IEEE Standards
Supported RFCs
Standard MIBs
Proprietary MIBs
ICMPv6 Type and Code
This section provides a procedure to configure Inter-VSN routing using the CLI.
